Message 1 of 2
Freeview issues
Last few months had really bad pixelation on sd channels and sometimes no hd at all.
But the bullet and had a new aerial fitted at xmas, seemed to fix for a few weeks  it has resurfaced tonight .
In frustration i switch the youview box off ( humax dtr2100) and once it had rebooted all was fine.
Was this just luck orcould there be a fault in the box ?
Had the boxfor around 2 years.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Freeview issues
@stanster whats the signal strength like?
You can check the TV signal and quality for the channel by:
  1. Pressing the Home (or YouView) button
  2. Going to Settings > Signal & Connection > TV Signal Quality
If the signal quality is less than 50%, this indicates that your signal is too weak to receive this channel. If you're signal is too high, this could also cause the issue. You could try connecting your set top box to another aerial port in your home (if you have one), to see if this makes a difference.
