Last few months had really bad pixelation on sd channels and sometimes no hd at all.
But the bullet and had a new aerial fitted at xmas, seemed to fix for a few weeks it has resurfaced tonight .
In frustration i switch the youview box off ( humax dtr2100) and once it had rebooted all was fine.
Was this just luck orcould there be a fault in the box ?
Had the boxfor around 2 years.
