Displaced_Geordie
Message 1 of 3
Freeview radio via YouView
I currently have my BT Youview Humax box connected to my TV by HDMI and by optical to my surround sound amp. The TV and Humax box are controlled by the Humax remote. I have found that when I listen to to the radio via YouView through the amp  with the TV turned off I am unable to change stations though with the TV turned on I can.
On the black BT Vision box I had changing stations without the TV being turned odiddle not a problem.
Does anyone know if this is a BT problem or should I flag it up on the YouView forums?
Thak you
2 REPLIES 2
cactusbob
Message 2 of 3
Re: Freeview radio via YouView
Flag it up on the YouView forums, don't mention it's a BT box though or they'll send you straight back here
Displaced_Geordie
Message 3 of 3
Thanks for the response. I have fixed or rather it has fixed itself. I turned off the power to all units, unplugged them and waited two minutes and then restarted the system and now it works like my old black BT Vision box.
