TonyR351
Message 1 of 6
Getting extra TV channels and costs
Hi,
I have had Infinity plus BT sport and TV essentials since July, I am looking to add the extra TV channels to this but am unable to find out how to do it.
What I would like to know is how much it will cost and if it will involve a new contract.
I have used the search to no avail so I am hoping to find the information on here.
Thanks for any help you may be able to give.
5 REPLIES 5
Starman
Message 2 of 6
Re: Getting extra TV channels and costs
Package details can be found here - http://www.productsandservices.bt.com/products/tv?s_cid=con_FURL_tv
Do you have BT Infinity Broadband or just regular ADSL Broadband?
BT Infinity (EASTF) 58.93/15.94 Mbps [IP Profile: 60.8/20 Mbps] using Openreach Modem & Billion BiPAC 7800N
Distinguished Guru
Distinguished Guru
Message 3 of 6
@TonyR351 wrote:
Hi,
Tony,
Log into MyBT
If you have a look at
http://www.productsandservices.bt.com/products/tv/compare-packages
there is a link near to the bottom of the page
My BT icon
Already got BT TV?
Upgrade your existing package
The standard price for the Essentials package that you have is £5 /month, the standard price for the Entertainment package which includes the 19 Extra channels is £7/month - so if you are paying standard rates it would be an extra £2/month.
You should be able to upgrade online via that link or alternatively ring up and place the order over the phone.
TonyR351
Message 4 of 6
Thanks for your replies, I have tried to upgrade via the link given and it is wanting to charge me an extra £7 pm which is unacceptable to me.
I am not prepared to risk signing up untill I am sure the cost will be only £2 pm and no increase in contract period and the telephone help is about as much use as a chocolate teapot, so I seem destined to not have the extra channels.
Not to worry and thanks for your advice anyway.
tassiekev
Message 5 of 6
Tony,
Had a very similar situation to yours, wanting to drop Movies and  add HD channels. I dialled 150 said "Change BTTV" to the robot and was put through to a real person immediately. That chap couldn't help but put me through  to 'Options' and a very nice Geordie lady did the changes there and then - took about 30 minutes for the changes to come through. Give it a try - the whole thing took 7 minutes. Give it a try.
TonyR351
Message 6 of 6
Thanks Tassiekev,
 That worked brilliantly, thanks for the advice, also thanks to all others who replied.
Tony R
