dpworth
Message 1 of 6
Getting second youview box
Hi I have my original (pre bt contract) humax connected to my home network and believe its possiable to get a second box  activated to mimic my main box (of course recorded programmess stay on each unit).
I have tried the bolton option and selected no change to current contract but added second subscription (less box) to find a) it will only process the order if i select either an engineer install or to purchase some powerline converters (which i dont need since im hardwired into my home network). All appears ok but then i get an error to say no upgrade paths.
Is it still possiable to have a second box or not, and if so how do i get it asctivated.
Anyone else running additional units around the home?
Cheers in advance.
5 REPLIES 5
Message 2 of 6
Re: Getting second youview box
dpworth
Message 3 of 6
Many thanks for the link but afraid it takes me to the same page the Bolton option did.
I can login and select no change, select the additional box for £5 a month but will then only progress if a) select to purchase the power line converters or b) an engineer install. When I then select continue to pay I get an error about no upgrade pathbring available.
Thanks again for the link. Looks like I’ll have to call someone.
Moderator
Moderator
Message 4 of 6
Hi @dpworth,
Would you like our help ordering it for you?
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
dpworth
Message 5 of 6
DanielS, if you were able to help getting the second box added to our subscription and activated it would be appreciated.
Darren
Moderator
Moderator
Message 6 of 6
Hi @dpworth We'll be happy to help with that, please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Kudos”Kudos”
