kryten22uk
Message 1 of 4
Grouping within Bookmarks?
If I bookmark a tv series, it adds all the individual episodes separately under the Bookmarks section.  Its quite frustrating to scroll through pages and pages to get to the right bookmarked programme.  Sky group series together so that you can see all your programmes at the top level, and then drill down to the next level (where relevant) to choose the specific episode you want.  This also is a feature of the main YouView catchup software, so why is this usability not on BT Vision?
3 REPLIES 3
notoriousdbp
Recognised Expert
Message 2 of 4
Re: Grouping within Bookmarks?
To be honest, the easiest thing is to use the YouView search and navigate through a series on there
---Remember to mark as 'solved' and give stars when you like a post---
kryten22uk
Message 3 of 4
..so effectively saying that the Bookmarks section is currently an unusable feature.
notoriousdbp
Recognised Expert
Message 4 of 4
Not necessarily, it's a few less button presses to get there using the YouView search, depending on where you're going from, that's all.
