Help us improve our customer experience. We are very keen to get your thoughts on some of the ideas we are exploring. Please take a few minutes to complete this short survey,
totally agree, it's the same as in the guide where you have to continually scroll through the SD channels or find and press the blue teletext button, what were they thinking ?
@srpsrpwrote:totally agree, it's the same as in the guide where you have to continually scroll through the SD channels.
What? No need to scroll through anything, mate. Just press 101 and your already there. Or just press Guide, blue button, right and your there again.
I can never remember where the blue teletext button is though and I'm used to using my Sky remote in the dark.
Every other TV related device I've ever used has put the button icons on screen in the same relative positions as they appear on the remote.
With the guide, I suppose I can remember that BT have done it back to front, i.e. the blue dot is on the extreme left of the guide and blue button at the far right of the remote! Someone really deserves a medal for that set up… not.
@srpsrpwrote:I can never remember where the blue teletext button is though and I'm used to using my Sky remote in the dark.
Treat yourself to a universal remote (eg Harmony) then you can get used to the buttons always being in the same place no matter which device you are controlling.
@QoQwrote:
Bit when you press blue home button
Ah! You mean the Youview/Menu button not the Blue sub-function (formerly aka teletext control) button.
@QoQwrote:
Is there a way to change the channels shown when you press the blue home button that then shows a slide of channels to get them to be HD.
+1
I have previously raised this on the main YouView Community as have others.
I don't watch anything in SD so would love an option to swap the defaults on this overlay for the HD versions.
