dfel100
Message 1 of 3
H2 intermittent loss of sound and picture
Does anybody have the same problem, where H2 has an intermittent loss of sound and picture about a second or so.  All other internet channels are okay?
2 REPLIES 2
Musher
Message 2 of 3
Re: H2 intermittent loss of sound and picture
Yes, exact same problem here.
The intermittent loss of sound and picture has been present since H2 became availible.
All the other IPTV channels (including the HD ones) work fine.
The funny thing is if I record a programme and then play it back I don't notice any loss of sound or picture.
BT infinity 2, Hub 5A, G4 Box.
I've reset the box (keeping recordings) and powered the Hub On/Off to no effect.
dfel100
Message 3 of 3
Thanks Musher, shame there is not a fix.  I will try the reset just in case
