Message 1 of 6
HD Channels
Started getting this problem on BBC1HD 101 ,Bbc 2 102,ITV 103,C4 104 Channel 5HD 105. The picture and sound is perfect but the screen goes completely blank with no sound at random intervals. The only way to bring it back is to key in channel number and it comes back on. Also on start up of tv from standby on a hd channel the message about “access to this channel is not possible “ which I had before was hoping that had been sorted. All internet channels work perfectly eg bt sport channels.Any help would be greatly appreciated. Don’t really want to do factory reset though.
5 REPLIES 5
Distinguished Guru
Distinguished Guru
Message 3 of 6
Re: HD Channels
Possibly some form of handshaking problem. i presume you are currently using an HDMI connection.
Not sure i recognise the  "access to this channel is not possible" error message - does it have a code which might clarify whether it is an error reported by your Tv or one from the Youview box ?
Message 4 of 6
Re: HD Channels
Error message is YVM607 I think . Had this problem several months ago. But the disappearing picture sound problem  on HD channels 1-5 happenend last night when I tuned into ITV HD  from BT Sport HD .
Message 5 of 6
Re: HD Channels
BT TV Expert
BT TV Expert
Message 6 of 6
Re: HD Channels
Hi @Bluemoon1
Sorry to hear you are having problems with the BT TV Service. If you're able to send me your landline number via a private message I'll be happy to have a look into the issue for you.
Thank you.
