fkm99
Message 1 of 18
HD Internet Channels
Hi - I realise that this may seem like a dumb question but I won't let that stop me.  I have a YV box on Infinity with the entertainment pack. I'm not terribly impressed with the standard definition picture quality of the internet channels (Fox, Syfy etc).
My TV has a built in Freeview HD Tuner and the HD channels quality is superb - live and recorded.
So my question is,  if I upgrade my package to include the £3 per monh HD bolt on, will I see a similar picture quality to that of my aerial delivered Freeview HD channels?  My Infinity download speed is around 37mbps.
17 REPLIES 17
ney
Expert
Message 2 of 18
Re: HD Internet Channels
I Also got a Freeview HD tuner on my 22inch Samsung TV in my bedroom and have a retail Youview box pluged into it as I got the BT Youview box in living room and the HD extra channels are very good and almost as good as the HD channels via the the HD tunner on my Samsung TV.
Darren
fkm99
Message 3 of 18
Thanks Darren - much appreciated. I will probably upgrade then 🙂
Distinguished Guru
Message 4 of 18
I find a huge difference and wouldn't hesitate to recommend the HD bolt ons
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
ab79
Message 5 of 18
I find the quality/ sharpness compared to freeview hd slightly better but to me the big difference is the movement. Sometimes on the freeview hd channels, the picture seems a bit jerky in panning scenes whereas the streamed ones are nice and smooth. It may be a better frame rate on the streamed channels or more compression on freeview hd? I'm not sure.
fkm99
Message 6 of 18
Thanks Stuart. I will do.
fkm99
Message 7 of 18
Interesting - I've now made my mind up to upgrade.
ney
Expert
Message 8 of 18
Glad to Help. You will love the HD extra bolt on.
Darren
scointer
Recognised Expert
Message 9 of 18
I agree and it might just get better soon Smiley Wink
Distinguished Guru
Message 10 of 18
Indeed it might 😉
Helpful Post?
