Message 51 of 124
Re: HD Signal Strength and Quality Issue
@glenhill68 wrote:
If I pull out the brown aerial cable from the UHF then I lose the tv signal. Is this the one then that feeds my tv?
Yes, try it on a different output, or bypass the amplifier when yo get the female joiner.
glenhill68
Expert
Message 52 of 124
Thanks for your help again.
No, the black aerial cable was connected to 1 on the side of the unit, not Full.
glenhill68
Expert
Message 53 of 124
Should i then have them all connected to the output or connect the black aerial cable to UHF?
glenhill68
Expert
Message 54 of 124
Getting far too complicated now lol.
I took out the brown cable from UHF and connected it to one on the side - no tv
I then connected the black socket to the UHF - no tv
glenhill68
Expert
Message 55 of 124
Connected it back to how it was originally.
Strength - 95-98%
Quality - 60's%
Then both drop to zero and picture breaks up.
Message 56 of 124
Strength - 95-98%
Quality - 60's%
Then try the variable attenuator, and adjust it to a srength of about 70%, I think its still a high signal level problem over loading the YouView box.
glenhill68
Expert
Message 57 of 124
I will try and pick one up later
Message 58 of 124
Hopefully, that should fix the problem. If it does not, then the only thing left is to get the aerial and distribution checked.
As I said before, the amplifier is very old and may be distorting the digital waveforms.
This may not be noticeable on a TV, which is much more tolerant of errors, but would upset the YouView box, or other DVR, which need a good error free signal to ensure reliable recording.
You could replace the amplifier yourself, as its quite easy and not expensive, and includes a 4G filter, which your old one would not have. Its possible that 4G is causing some issues, so having a filter would be beneficial.
Here is one that should be suitable.
SLx 27820HSG-4G Four Output Aerial Distribution Amplifier – 4G Compatible £13.49
There are for outlets (left) and one input (on the right). The other connector on the right is for feeding additional distribution amplifiers.
Changing it would bring the system up-to-date.
glenhill68
Expert
Message 59 of 124
This any good    Nikkai Aerial Amplifier with Digital Bypass 6 Way
glenhill68
Expert
Message 60 of 124
Ignore that link, no stock. Will try variable attenuator first then look at new amplifier, that one you mention is £11 on Amazon.
