gdm1
Newbie
Message 1 of 3
HD channels
Morning
New user here. I set up my box yesterday, and on the whole everything is fine (much better than my old box). The only thing is, I can't get any HD channels? I got them on my old box, so the signal is good enough. Is this typical? Should I retune and see if that works?
Cheers
Graeme
Tags (1)
2 REPLIES 2
drhowells
Recognised Expert
Message 2 of 3
Re: HD channels
Hi, just to check.....what happens when you go to channel 101 (BBC 1 HD) on the box?
gdm1
Newbie
Message 3 of 3
Re: HD channels
Turns out it was my fault. I've signed up to Vision+ as opposed to YouView. All sorted now - have to say Customer Services were excellent, they cancelled the service and set up YouView, arranged a new box and returning of the Vision+ box
