Message 11 of 21
Re: HD issues with you view box
The channels listed are freeview not internet?
Ryanharvey
Message 12 of 21
It's just every HD channel. I've changed my hdmi cable also. All be it a not very expensive one.
skappy70
Recognised Expert
Message 13 of 21
If it's the Freeview HD channels only then you need to check your local transmitter isn't having any issues, check your aerial connection is good and away from other cables behind the YV box/TV. What signal strength/quality do you get with the HD channels?
Ryanharvey
Message 14 of 21
Signal strength is 25% signal quality is 100%. I realise the signal strength is quite low but it has always been like this and never had an issue up until the last few weeks. When I connect an aerial tester to my aerial it says strength is good?!?
skappy70
Recognised Expert
Message 15 of 21
Have you checked for any engineering work in your area? http://www.digitaluk.co.uk/help_and_advice/engineering_works
it may also be 4G interference if a new mast has become operational in your area recently but that should affect all channels not just HD.
Ryanharvey
Message 16 of 21
Thanks skappy. Just checked. No planned work in my area.
Message 17 of 21
25% is too low
The youview box wants 75% or more to avoid glitches
Ryanharvey
Message 18 of 21
Been in the loft and done some re wiring. Strength is now at 70%. First HD channel I put on it pixelated! 😒
speedtrip
Expert
Message 19 of 21
Mine is fine on a 25 year old Loft installed aerial - I get a fluctuating 65-72% max What are the Channels like on the TV itself .... ie the aerial coax straight to the TV, with no BT box in the equation ?
Ryanharvey
Message 20 of 21
Straight into the tv everything is perfectly fine. It is only the HD channels which are causing the issues.
