Message 1 of 8
HDMI compatibility problem with new Youview box
Just got a new Youview box because of the discontinuation of iPlayer on my BT vison box. It seems to be cycling round trying to find a compatible display mode. The screen displays then flashes and goes blank in a continuous loop. The old BT vision box (black) and my pc are able to connect via HDMI so pretty sure its not the TV and pretty sure its not a faulty youview box.
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: HDMI compatibility problem with new Youview box
Hi @arjayjay Did you get this problem solved? Post back and let us know.
Cheers
John
Message 3 of 8
I tried updating the Youview software. Switching between 720 and 1080 gets it working but when I go in and out of standby the problem comes back. This is defintely a Youview problem. Everything else I have tried with the TV is ok including the BT Vision box.
Needs looking at by the test team at Adastral Park.
Moderator
Moderator
Message 4 of 8
Hi @arjayjay Thanks for the update.
We will be happy to look into this further for you if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
Message 5 of 8
Hi John. Someone phoned to say Adastral Park would be in touch but I haven't heard anything. iplayer stops on the 28th April.
Moderator
Moderator
Message 6 of 8
Hi @arjayjay Neil has raised the case into them and he is awaiting an update. He will be back in touch with you tomorrow.
Cheers
John
Message 7 of 8
Ok thanks. I accidentally raised a new case instead of replying here so feel free to delete it **edited by Mod**
Moderator
Moderator
Message 8 of 8
Hi @arjayjay Thanks I noticed that and will get it closed.
Cheers
John
