maathoru
Message 1 of 19
Haloing / Edge Enhancement on YouView signal
Hi - I just got a YouView+ box and am really happy with the functionality but there is problem with the signal which is showing signs of edge enhancement resulting in haloing
This image shows the tv signal through my tvs inbuilt freeview (samsung TV) - the picture is sharp but solid
This picture shows the same channel coming through the YouView box - note the edge enhancement and haloing:
This next picture shows an image from Netflix via the YV box - note the excessive haloing around the character:
I have the picture settings the same for all inputs (sharpness etc) and all picture processing is switched off on the TV - Images from my Blu Ray player via HDMI do not display the same issues. Could anyone shed any light on this issue?
18 REPLIES 18
maathoru
Message 2 of 19
Re: Haloing / Edge Enhancement on YouView signal
ok - i have just set the tv sharpness level to 0 for YouView for best results
skappy70
Recognised Expert
Message 3 of 19
That's what I like about Samsung TVs each input has its own settings.
gomezz
Recognised Expert
Message 4 of 19
Indeed. Bearing in mind that each input will have its own manufacturing tolerances so the notional settings used on one may need a slight tweak for another even when used with the same connected device.
Distinguished Guru
Distinguished Guru
Message 5 of 19
Personally I have found that I opt to adjust my  default TV picture settings whenever I acquire a new device including on the most recent Youview+ box where I opted to reduce the default TV sharpness setting.
There are a variety of  TV reviews and articles  out there
In this article
http://www.techradar.com/how-to/television/tv-setup-guide-14-tips-for-getting-the-best-picture-quali... it says
If you think that by increasing sharpness you'll get more detail in your TV images then you're probably going to be disappointed. Out of the box the sharpness on all presets will invariably be set too high. Look at black text on a light background: does it have a white glow or ring around it? This extra emphasis improves legibility when viewed at a distance but does not improve detail, it actually obscures it. And on a 4K TV, meant to be viewed larger/closer, this is a particular no-no. Often Sharpness should be no higher than 10/15 on the adjustable gauge.
maathoru
Message 6 of 19
I'm disappointed that turning the sharpness down to 0 on the YouView input on the samsung does not completely eradicate haloing on the image - it's very subtle and stands out more when there are areas of high contrast on the screen - the overall effect gives the image a slightly more artificial quality than the equivalent on the tvs freeview signal. It's not there on the blu ray input - I've been trying to find a solution to this everywhere but am stuck. One possible solution may be to find a way to soften the image on the TV but so far have not found a way to do this - I've seen some posts suggest that renaming the input can open up new options but not sussed that one yet.
maathoru
Message 7 of 19
OK - finally - I did  a factory reset on the youview box and it has got rid of the problem - fingers crossed I hope it stays sorted
maathoru
Message 8 of 19
Haloing is back again - starting to feel lilke i'm losing my marbles here
maathoru
Message 9 of 19
I've found that setting the output of the YouView box to 1080i instead of 1080p gives better results - give it a go it you are having similar issues with your setup
maathoru
Message 10 of 19
Ultimately the only way to address this issue is to reboot the box which takes a good few minutes - this will eradicate or at the very least lessen the halo effect but it does return eventually for some reason and I have to reboot again
