Message 1 of 3
Help please. How to use Search for TV shows on Android App
Hi,
First time poster etc!
After 19 years of Sky we last week switched to BT TV.
We are currently trying to retrain our brains from the Sky method when recording to the BT version.
I have already paired the phone and box and can record a show when clicking on it in menu screen.
However, I wanted to find a TV show later in the week that is available on our Now Sub. Every time I typed in the show (with and without punctuation or spaces) no tv show was revealed. All I got was either a blank or something similar from the BT pay for version. If I scrolled through to the date and time, I can find it but that surely defeats the object of the search facility.
Where am I going wrong?
Any help would be greatly appreciated.
Many thanks.
2 REPLIES 2
Message 2 of 3
Re: Help please. How to use Search for TV shows on Android App
Is this the BT TV app on Android?
If so, then when you've typed your search criteria and hit search, tap the "On Now & Later" heading to show search results from the TV Guide.  If it's not shown there, let me know what you're searching for and I'll check what's happening.
Message 3 of 3
Superb. Many thanks. I've got it yo work. I hadn't pushed now/later after search. I had pushed now/later then search but nothing worked!
Thank you so much for responding.
