nbanbury
Message 1 of 5
How do I get a BT TV Pro Box?
Question in the title.  Currently have VIP TV package. Any ideas?
4 REPLIES 4
NeilO
Moderator
Moderator
Message 2 of 5
Re: How do I get a BT TV Pro Box?
Hi @nbanbury You'll need to place an order for the BT TV Pro box in MyBT or with the Value team on 0800 800 150.
Neil
nbanbury
Message 3 of 5
Thanks. I've tried both of those options and they don't work. Nothing available in MyBT and when I spoke to an operator they couldn't see any way to sell me one in their system. Should I call again?
DavidM
Moderator
Moderator
Message 4 of 5
Hi @nbanbury and thanks for the reply.
I'm sorry the advisor wasn't able to help you. Can you please try calling again, if you get the same response let me know and I'll look into this for you.
Cheers
David
nbanbury
Message 5 of 5
I will. Thanks!
