TractorGirl327
Message 1 of 3
How do I restore a single channel
absolutely loving my YouView box and thought I was being really clever and went through hiding channels we don't watch
However there are a couple of channels that I hid in error and I can't work out how to restore them. I've found the option to restore All channels but I don't want to do that, just the couple I hid by mistake
Can anyone help?
TractorGirl327
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: How do I restore a single channel
there is a workaround -  use Youview search to search for a program that is broadcast on that (hidden) channel - the search results will find the program but indicate that the channel is hidden - select the program and it should give you the option to unhide that channel.
TractorGirl327
Message 3 of 3
You superstar, that worked!
Brilliant , thank you xx
TractorGirl327
