yorksteve
Message 1 of 10
How to control TV with an old BT Youview remote
remote.pngI have a YouView remote like the one picured. Can anyone tell me the key sequence to press before I enter the four digit code to allow it to switch the TV on and off? All of the instructions I can find talk about the TV and AV buttons, but this remote doesn't have those.
9 REPLIES 9
Keith_Beddoe
Message 2 of 10
Re: How to control TV with an old BT Youview remote
@yorksteve
That looks more like a remote control from the old obsolete Vision+ boxes?
yorksteve
Message 3 of 10
Well, it is a few years old, with buttons for Youview and BTVision, and works with our BT YouView box.
zulu17
Distinguished Guru
Distinguished Guru
Message 4 of 10
I believe it is the remote supplied with the early BT T1000 Youview boxes which had a very similar look to the BT Vision box remote of the time .. Youview button towards the top left.
yorksteve
Message 5 of 10
Yes, YouView is the blue button near the top left. Our old identical remote could switch the TV on with shift/AD & power button.
zulu17
Distinguished Guru
Distinguished Guru
Message 6 of 10
I believe it is  holding the VOL- and mute remote keys for five seconds  gets you into the setup for the remote
then you would need the right code for your TV.
yorksteve
Message 7 of 10
Thanks - that works. Glad to be back to just one remote!
tomduffy
Message 8 of 10
Hi, can I ask what code you used?  I am trying 4483 for my Samsung but no joy.  I am holding mute & VOL- until it flashes 3 times, entering the code, but the remote still doesn’t operate the tv
DavidStiff
Message 9 of 10
I found this  list of codes, 0736 worked for me. 8D9F4212-B168-4201-A5A8-C4E6BF7A1AAE.jpeg
Bilbo_Baggins
Message 10 of 10
You are right, Zulu17, I did as you said and it worked. Thanks
