angeljs
Message 1 of 6
How to order Extra Box
I have two BT TV boxes and want one in my bedroom. I checked the BT help section which had a link to order Extra Box, but it just led to my products page with no way to order it. How do I do it, please?
Also, I have a WiFi disc which I've been asked to return as I've downgraded my package. Is it possible to buy it?
(By the way, someone should probably update that help section.)
5 REPLIES 5
JohnC2
Moderator
Moderator
Message 2 of 6
Re: How to order Extra Box
Hi @angeljs, thanks for posting, and sorry you could not order the Extra Box service. Do you have Fibre broadband with speeds of 23Mbps or more and a separate aerial connection for your second box?
The Wifi disc you have would have to be returned. If you wish to purchase one it can be ordered Here.
Cheers
John
garybs29
Recognised Expert
Message 3 of 6
If you already have 2 boxes you can't order anymore, you can get a maximum of 2 boxes
angeljs
Message 4 of 6
I know that, I'm talking about the Extra Box service.
angeljs
Message 5 of 6
Yes, I have a second aerial. It seems silly that I have to return the disc only to purchase a new one. And they are £100 each! Really? I can't afford to pull that out all at once.
JohnC2
Moderator
Moderator
Message 6 of 6
Hi @angeljs, thanks for getting back to me and we'll be happy to help you get the Extra Box service ordered. I've sent you a Private Message with details on how to contact the Mod team.
There is no process to purchase outright a disc that has been sent to you already. This has been mentioned before so have a look at This Thread.
cheers
John
