Do you mean
Newbie
Humax no signal
My telly keeps telling me there is no signal when everything is plugged in correctly. It has happened a couple of times now. Last time Afrer fiddling around it eventually came back on but this time, not to far! Any ideas?
Moderator
Re: Humax no signal
Hi @Gusta Sorry you are having problem with your BTTV.
Are you still experiencing this issue? Is it possible there is a loose connection somewhere in the set up?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
