SXBouy
Message 1 of 4
I Can't Watch Any Payable Services On My BT TV Recordable Box G4
Whenever I attempt to view BT Sport or UK Gold (or any other channel that I pay for) I just see a black screen that will slowly change to the viewed channel but be so pixelated and covered in a mainly green colour, that it is unviewable.
I can see these channels on my phone via the BT Apps.  I have completed a factory reset and also restarted the whole network at the same time.
I would raise a fault but can't be bothered to sit on the phone for another 30 mins
Any ideas any one?
Thanks in advance
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: I Can't Watch Any Payable Services On My BT TV Recordable Box G4
How is your box connected to your hub and do you see any error messages
SXBouy
Message 3 of 4
It's connected via the Ethernet and the BT Mini Connector plugs.
Anonymous
Not applicable
Message 4 of 4
The mini connectors would be my prime suspect. You need to do whatever is necessary to eliminate them. I suggest you move the box to within reach of the hub and connect it using an Ethernet cable
