Arqiva are doing some engineering work at the moment, you may need to re-tune.
There were several Freeview changes effected yesterday 22 June - were you prompted to retune and have you done so since yesterday .
Arqiva is closing down one of its temporary Freeview multiplexes (COM8) and the channels on its other temporary multiplex (Com7) have been adjusted. As Freeview is operating with one less multiplex some channels will cease on the platform.
Current channel allocation as published by Freeview is
https://www.freeview.co.uk/corporate/platform-management/channel-listings
I have tried retuning the box still can't receive the HD channel I am in west Yorkshire
That puts you on the Emley Moor transmitter, BBC4HD channel should be on 106
That is correct when I could get the chabbelit was 106 I have lost all the channels after 105 the next is 201
You'll no doubt think I'm losing my marbles, but try 781 (some channels are moving temporarily before being ceased)
Edit:
Channel name Channel number
Shopping Quarter | 74 |
BBC Four HD | 106 |
CBeebies HD | 205 |
QVC HD | 111 |
QVC Beauty | 112 |
Quest HD | 114 |
FreeSports | 64 |
NOW 80’s | 83 |
PBS America + 1 | 93 |
Forces TV | 96 |
Together+1 | 89 |
CBS Drama | moving channel from 71 to 67 |
The above services will be available temporarily from channel 780 onward until 25 June 2020 except for CBeebies HD which will be available temporarily from the Kids genre section of Freeview, also until 25 June 2020.
https://www.freeview.co.uk/help/22-jun-2020-channel-broadcast-changes
781 comes up as no channel
It's going off air for the foreseeable from tomorrow anyway, maybe they've taken it off a couple of days early.
@Stevehill Looks like you currently have issues with both the Com 7 and Com 8 reception on the BT Tv Box .
If you plug the aerial lead directly into your TV do you also experience the same absence of the channels. You may need to retune the TV as well due to the Freeview changes recently ?
