jptykes
Message 21 of 24
Re: I don't want ITV Granada
Box details
Humax
DTRT2100
84B08500
Software details
3.3.108(a1e16e)
29.45.0
gomezz
Recognised Expert
Message 22 of 24
I think to get the transmitter option to come up it is not sufficient to just select the retune channels options but you need to do a full reset instead. If you boot up in maintenance mode then you can do the reset without losing your existing recordings but you will lose your other settings (eg Sound Mode, Audio Delay etc) so will need to redo those.
jptykes
Message 23 of 24
Thanks. I'll try that tomorrow.
V_Meldrew
Recognised Expert
Message 24 of 24
@jptykes wrote:
Box details
Humax
DTRT2100
84B08500
Software details
3.3.108(a1e16e)
29.45.0
Thats exactly the same model and software build of the box I took the screen shot of earlier, I think that confirms that your box is the cause of the problem.
I suspect you may be able to rectify it just by doing a Software Reset from the maintenance menu but you will still have to retune it to get Yorkshire TV
