veryhandy1
Message 1 of 7
IOC 6023 after broadband upgrade
Since my broadband was upgraded 3 days ago I am unable to watch any internet tv channels, internet working and all apps and players working
when I try any subscription channel btsport or discovery etc I get error code Ipc 6023
bt are struggling to resolve
6 REPLIES 6
Message 2 of 7
Re: IOC 6023 after broadband upgrade
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 3 of 7
Hi @veryhandy1
Sorry you're having these problems after upgrading your broadband package. I can get this looked at for you.
I've sent you a private message with details on what we need to investigate, you can view your private messages by clicking this link
Stuart
Community ModeratorStuartH
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
TimCurtis
Recognised Expert
Message 4 of 7
@veryhandy1
What was the upgrade that you had?
If it was ADSL to Fibre then it might well be a few days before all services are resumed.
Also sometimes a router reboot & a Youview box reboot can solve this type of issue.
veryhandy1
Message 5 of 7
Hello, I had my bt infinity broadband upgraded to ultrafast broadband on 28th Jan and since then no subscription channels, looks like it is a multicast problem
veryhandy1
Message 6 of 7
My Subscription TV issue has now been resolved, as first described I had no Subscription channels after a Broadband upgrade from Infinity to Ultrafast.
Internet was workin OK and all Apps and Players were working also i had all EPG for all channels just no Subscription channels
After reading similar issues on this forum it was clear it was a multicast issue and thanks to Stuart H from BT who seen my post and took up the baton.
It was a config Issue which has now been rectified and all channels are now accessible
Thanks to all involved
Moderator
Moderator
Message 7 of 7
Hi @veryhandy1 Thanks for the update and I'll let @RobbieMac who called you earlier today that this is now fixed.
Cheers
John
Community ModeratorJohnC
Kudos”
