ndavis
Message 1 of 9
IPC 6023 Error.....PLEASE HELP!!!
Hi I'm hoping someone on here can help.
My services were activated on 5th May and as yet I haven't managed to watch a single channel on my new youview box.
I have already had an engineer out who believed the issue was that the channels hadn't been provisioned correctly.
I can use my broadband on all other devices great, I've had Bt Infinity 2 with the new smart hub. I have the UHD youview + box.
I can watch my subscription channels on the BT TV app, I'm registering a speed of approx 55-60 Mbps downstream and 17-20 Mbps upstream.
I've reset my youview box and updated the software countless times, the same with my router. I have another engineer coming out next week but after many hours of online live chat, phone calls and an engineer visit already, I don't hold out much hope for this being sorted. I'm fairly Tech savvy so I know I'm not making a simple mistake in set up.
If anyone can help, I would be most greatful.
Thanks in advance
8 REPLIES 8
Message 2 of 9
Re: IPC 6023 Error.....PLEASE HELP!!!
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
ndavis
Message 3 of 9
Thank you. I look forward to hearing from someone as this issue is driving me bonkers.
Moderator
Moderator
Message 4 of 9
Hi @ndavis and welcome.
I'm sorry you're having problems the the 6023 error message. Can you try Fix IPC 6023 error code and let me know if that helps. If you're still having problems our TV specialist @Martin--W might be able to lend a hand.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
ndavis
Message 5 of 9
Hi there. Thanks for your help so fare but unfortunately I have already completed these steps several times over.
I've checked everything I believe I can without getting int incredibly technical tasks.
Your help is appreciated.
V_Meldrew
Expert
Message 6 of 9
Do you have a direct ethernet connection between your router and your stb or are you using a network hub of some kind? some hubs are not too good with Miracast.
BT TV Expert
BT TV Expert
Message 7 of 9
Hello @ndavis
If you would like to Private Message me your phone number or account number I will look into this for you.
Kind regards,
Martin.
Community ModeratorMartin
Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
ndavis
Message 8 of 9
Hi there.
I am connected directly into the Hub via ethernet cable and have tried in all 4 ports on the router as well.
V_Meldrew
Expert
Message 9 of 9
I had this problem a few years back and managed to find a solution that worked for me but met with indifferent reaction from others on the forum who had the same problem. Still if you want to try it this is how I did it.
Log onto your router and note the DHCP address range and DNS server address, Log off of the router
Go into network settings on your STB and allocate a static IP address which is not in the routers DHCP pool.
Set the DNS address to the one noted from the router settings.
