Mattaber79
Message 1 of 8
IPC 6023
Hi, my you view box won't play any hd channels, tried resetting everything but stil comes up with IPC 6023... Help!! All the on demand services work great, just the hd channels that won't work!
Tags (1)
7 REPLIES 7
Moderator
Moderator
Message 2 of 8
Re: IPC 6023
Mattaber79,
Welcome and thanks for posting. Sorry you're having poblems with the error message. Take a look at 'IPC' error codes on YouView and let us know how you get on.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Mattaber79
Message 3 of 8
Re: IPC 6023
Hi David,
All my connections are fine, also my speed is good - everything works apart from the hd channels also uk gold!
Cheers
Moderator
Moderator
Message 4 of 8
Re: IPC 6023
Thanks for confirming that Mattaber79.
If you're still having problems we'll need to take a closer look so drop me an email with your details. You'll get the 'contact us' link in my profile.
Cheers
David
Kudos”Kudos”
V_Meldrew
Recognised Expert
Message 5 of 8
Re: IPC 6023
I had this problem (note past tense), in my case it appears to be a problem with my Homehub5, I found a way to compensate for it which I'll keep as simple as possible.
1. Login to your Homehub and note the primary and secondary DNS addresses. Log out of the homehhub.
2. Change the Network Settings on the youview box to Manual but don't change the IP address, IP mask or Gateway addresses.
3. Enter the primary and secondary DNS adresses noted in step 1. Confirm changes and exit Network Settings
That's all it took to get mine working properly. Good Luck
skappy70
Recognised Expert
Message 6 of 8
Re: IPC 6023
I tried the above on my G3 box but it didn't like it and wouldn't save?
V_Meldrew
Recognised Expert
Message 7 of 8
Re: IPC 6023
I don't know what a G3 box is (mines the DTRT2100) but I can't think of any reason why it shouldn't save, its just basic IP networkin. Did you get any sort of error message returned ?
rarmitage124
Recognised Expert
Message 8 of 8
Re: IPC 6023
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
