ian_hailstone
Message 1 of 2
IPC 6041
I recently upgraded to HD pack on bttv and i can watch all the HD channels no problem.  when i try to record Hd channles that i subscribe to i get the message check the connection between your box and router then restart the router IPC 6041 when i try to watch them
i reset the router and the youview box and still receive the same message. i can record and watch channels that i subscribe to in SD
i did google the message and it isnt much more help than the box
please can someone help
1 REPLY 1
BT TV Expert
BT TV Expert
Message 2 of 2
Re: IPC 6041
Hello @ian_hailstone
If you'd like to Private Message me your phone number or account number I do what I can to help.
Kind regards,
Martin.
