Message 1 of 2
IPC6007
Was working fine till about 30 minutes ago
1 REPLY 1
Recognised Expert
Message 2 of 2
Re: IPC6007
Presume your problem might be similar to that detailed in an old thread. Check whether the solution mentioned works for you.
https://community.bt.com/t5/YouView-from-BT/IPC6007-error/td-p/1846492
