Message 11 of 33
Re: IPC6023 #2
You would need a managed or "smart" Ethernet switch to allow the multicast data to be passed. Most unmanaged switches will not do IGMP snooping, and pass the data to the YouView box, and stop BT Sport and any of the extra channels.
If you are using an old router as a switch, then its not going to work.
Message 12 of 33
Re: IPC6023 #2
@mattswain24 wrote:
just purchased a new router from curry’s this was £19.
What did you need that for, the home hub is the only router you need?
If you just need more Ethernet ports, then an Ethernet switch ia all that is needed. If you need more wirleless coverage, then a wireless access point is what you need.
V_Meldrew
Expert
Message 13 of 33
Re: IPC6023 #2
Return it and ask if you can swap it for an unmanaged switch, odds on that's the cause of your problem.
You can prove it if you have a long enough lead simply by connecting direct to the main hub
V_Meldrew
Expert
Message 14 of 33
Re: IPC6023 #2
With respect Keith, I beg to differ. I use an unmanaged switch with my own setup with no problems.
Message 15 of 33
Re: IPC6023 #2
Some unmanaged switches are "smart" switches. Which one is it that you are using?
There is a thread relating to this issue. https://community.bt.com/t5/Connected-Devices-Other/BT-Sport-4K-problems-with-NOW-TV-SMART-box/m-p/1...
V_Meldrew
Expert
Message 16 of 33
Re: IPC6023 #2
Mine's a Netgear GS608
Message 17 of 33
Re: IPC6023 #2
The Netgear GS608 is a smart Ethernet Switch. It looks at the layer 2 tags, and not just the physical MAC address like cheap network switches do.
http://www.downloads.netgear.com/files/GDC/GS608/GS605_608_datasheet_13May2004.pdf
V_Meldrew
Expert
Message 18 of 33
Re: IPC6023 #2
Only to layer 2, multicast utilises layer 4
mattswain24
Message 19 of 33
Re: IPC6023 #2
The viewboxs works with catchup tv. Just live bt sport not working
V_Meldrew
Expert
Message 20 of 33
Re: IPC6023 #2
Before we go any further could you confirm your network setup please. Based on your previous posts I believe it to be as follows:-
Your main hub (the one with the internet connection) connects to a secondary hub via powerline adapters and your youview box is connected by cable to the secondary hub. Is this correct and what hubs are you using?
