mattswain24
Message 21 of 33
Re: IPC6023 #2
My setup is
Internet to bt home hub 5 then ethernet cable to netgear router the ethernet to talktalk power adaptors then other end talltalk to tLink router to youview box.
Hope this helps. Many thanks so far
V_Meldrew
Recognised Expert
Message 22 of 33
Re: IPC6023 #2
@mattswain24 wrote:
My setup is
If you look at other posts on this forum regarding this problem I think you'll find that the HH5 is a common theme.
Message 23 of 33
Re: IPC6023 #2
@mattswain24 wrote:
My setup is
I am not surprised at all that it does not work, apart from the online players, which do not use multicast.
See https://community.bt.com/t5/YouView-Boxes/BT-TV-Channels-pixellating-and-stuttering/m-p/1698537#M330...
Just run it direct using a cable, or via the BT approved Mini Connectors.
Forget the Netgear router as the Ethernet ports are not going to pass the multicast stream. Even the TT powerline adapters may also have problems. As for the TT router, I can see problems there as well.
As I said, a router is not a suitable substitute for a proper Ethernet switch, as they are designed to route from the WAN side to the LAN side.
V_Meldrew
Recognised Expert
Message 24 of 33
Re: IPC6023 #2
@Keith_Beddoe wrote:
@mattswain24 wrote:
My setup is
My initial response was the same as Keiths but then I thought perhaps there is a confusion in terminology here. Not knowing how technical you are, apart from the HH5 do any of the routers you are using have internet capability or are they just local network switches?
Message 25 of 33
Re: IPC6023 #2
My guess is that @mattswain24 is just using them as Ethernet switches, as they were spare, and did not involve spending any extra money. This seems to be a common thing people try, despite the fact that they are not designed for that purpose. These were probably left over from another ISP, and would be best taken for recycling.
I think a network re-design is needed, using elements that are designed for the task.
V_Meldrew
Recognised Expert
Message 26 of 33
Re: IPC6023 #2
My own thinking exactly. If he is using old ISP routers then replacing them with network switches such as the one I'm using, of course there are others that would work equally as well, should greatly improve things.
mattswain24
Message 27 of 33
Re: IPC6023 #2
These routers are all fairly new and as i live in an old house with very thick walls need these routers fir the wifi around the house. The only area that my need replacing in the power adaptors. Do you think this will solve tge problem?
Message 28 of 33
Re: IPC6023 #2
Routers are not what you needed, and are not intended for that purpose, they are designed to be used to connect directly to a broadband line or modem.
To improve wireless coverage you should use either Wireless Access Points, or use something like these.
https://www.shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-multi-kit-084289-BVFH.html
Which are specifically designed to do what you want.
They are cheaper from places like Amazon.
You cannot use them with your existing powerline adapters.
mattswain24
Message 29 of 33
Re: IPC6023 #2
Would love to use these but my power is on 2 difference rind mains.
Message 30 of 33
Re: IPC6023 #2
Provided they all originate from the same consumer unit, they will work just fine.
They do not have to be on the same ring main.
