BT TV Expert
BT TV Expert
Message 11 of 109
Re: IPC6023 - Advanced Diagnosis
Hi Alan, sorry I should have said, it will need to be a homehub 3, 4 or 5.
There are some guides on this forum on configuring non bt routers (I'm mobile so can't look them up easily)
Steve
vintagewireless
Message 12 of 109
Hi Steve,
Should BT have given me a hub upgrade for BT Vision?
I'll check out the forum for router config.
Alan
TimCurtis
Recognised Expert
Message 13 of 109
There's a section in the manual that refers to "Movie Engine" aand multicasting & snooping (page 68) , whether that's relevant to this problem I'm not sure.
vintagewireless
Message 14 of 109
Hi Steve,
BT are sending me a HH3 as a swap for my HH2.
Thanks for your help.
Alan
vintagewireless
Message 15 of 109
Hi Tim,
To which manual are you referring.
Alan
BT TV Expert
BT TV Expert
Message 16 of 109
Excellent, thanks Alan
TimCurtis
Recognised Expert
Message 17 of 109
@vintagewireless wrote:
Hi Tim,
Alan
The manual for your router.
colincase
Message 18 of 109
Thanks for the suggestion of using VLC - that worked fine with my HH3 - long stream with no interuption (>15 mins)
However, my box still gets stuck at the 4mins 22seconds point with all internet channels. I have done a complete reset (losing my recordings - but they were only the first 4 minutes anyway!)
Of course, I can make it work if I am watching (OK-back-OK every 4 minutes or so) but that doesn't fix a recording.
This is drivng me mad - sadly this just isn't a production system at the moment.
The 256 second plus a few seems well known - why is it still a problem??
Software 17.3.0
Component 2.4.0
PlatConfig 910
ISP Config 90
all just refreshed
BT TV Expert
BT TV Expert
Message 19 of 109
Can you watch a channel for more than 4 minuntes when every other device on the network is unplugged? It sounds like a device is taking over the IGMP reporting from the youview box.
Steve
colincase
Message 20 of 109
unplugged all ethernet cables (except box) also turned off wireless
so box only thing connected to HH3/Infinity
same IPC6023 at the same time - 262 seconds
totally repeatable every time with internet channels
VLC fine on test stream
can I try VLC on "live" streams? like Alibi or something?
broken box?
