alexsheehan
Newbie
Message 1 of 4
IPC6023 Error - Constantly!
Hello Had YouView installed a few weeks back and have been getting really poor reception and constantly getting 'IPC6023' Error. When I switch back to Freeview, the picture is fine! I am on Fibre so this shouldn't be an issue and I constantly stream iPlayer, Xbox, download films etc. without any issue/drop in speed. Can somebody please help me? I have YouView connected directly to the router via Ethernet cable so it isn't a signal issue. Thank you Alex
Tags (2)
3 REPLIES 3
skappy70
Recognised Expert
Message 2 of 4
Re: IPC6023 Error - Constantly!
Could be cable interference, check for power and HDMI cables nearby, try another port on the Hub.
alexsheehan
Newbie
Message 3 of 4
Thanks skappy, but I've tried all those things!
Tried different sockets, cables, ports, different distances to hub, turning off everything but hub/YouView/TV etc. - none of it seems to make a difference!
Dkellz
Message 4 of 4
Hi Alex
I received my BT youview box yesterday and finally set it up today.  I kept getting the same issue (IPC6023) for a few of the channels such as History channel, Fox, Sysfy etc.
I'm not using the BT Home Hub as I sent it back to BT, i'm using a Netgear Nighthawk R7000 router instead.  I came across this article: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-cant-get-to-work-with-iptv/td-p/513192... mentions "Most IPTV providers use IP Multicast but most firmware for consumer routers have little to no support for IP Multicast".
It mentioned for the Nighthawk R7000 that "Disable IGMP Proxying" needs to be deselected so i accessed my router property page and downloaded the latest firmware update for my router and then disabled IGMP Proxying and now i can view the channels that I was only getting IPC6023 before.
I'm not sure how much this helps as I guess you must be using a different router but hopefully this will point you in the right direction.
I just noticed that StephanieG has put up instructions on how to enable multi casting for a number of routers.
 006
