Message 1 of 6
IPC6023 and new Smart Hub 2
Morning
I have been an Infinity 2 customer for several years using a Home Hub 5. We like to watch BT Sport (rugby) at the weekends.
Approximately 2 weeks ago we renewed our Contract to the Halo 2 with a new Smart Hub 2. Ever since we get error code IPC 6023 every 4 minutes watching any of the BT Sport channels. You can clear it by changing channels but then only works for 4 minutes.
I've tried everything i.e. checking all connections, changing ethernet cables etc etc to no avail. I was so fed up yesterday i put the old Home Hub 5 back in and it all worked fine i.e. no IPC 6023 error code. What does this mean?
Can anyone help please?
5 REPLIES 5
Message 2 of 6
Re: IPC6023 and new Smart Hub 2
@Surfbum
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Unless you are planning to use the add-on black disks, I would keep using the HH5.
Message 3 of 6
Thanks for this i'll give it a try later.
The dilemma i have is that the Smart Hub 2 was giving us a far better wifi signal around the house than the HH5!
Hopefully your suggestion will sort it and we can use the Smart Hub.
Message 4 of 6
I’ve turned off the Smart Set up as advised but it’s still giving the IPC6023 error.
Any other thoughts please?
Distinguished Guru
Distinguished Guru
Message 5 of 6
Message 6 of 6
maybe a new fibre white box will do the trick then.....
