Tompage51
Message 1 of 13
IPC6023 error issue
Hello all
I am after a bit of help/advice to try and fix the dreaded ipc6023 error on my BTTV service. My current setup is
Draytek vigor 130 setup in bridge mode
Netgear R8000 with the tick box for BT igmp/snooping setting ticked.
BT mini connector power adapters connecting  to two bttv youview boxes.
I have been using this setup for a while since my bt smart hub 1 decided to stop working after a power cut. the setup has been working fine but around about a month ago it started to drop the premium and bt sport channels with the good old ipc6023 error.
I have tried resetting all the devices but with no luck. i have also followed the diagnostic help on the BT website.
looking at other peoples issues and solutions on here and trying all of them i could find, i cannot see where i am going wrong.
Any help is most grateful
Kind Regards
Tom
12 REPLIES 12
JohnC2
Moderator
Moderator
Message 2 of 13
Re: IPC6023 error issue
Hi @Tompage51  welcome to the forum and thanks for posting. Sorry you are getting the IPC6023 error code. I notice you previously used the Smart Hub until it went faulty. If you are still in contract I will be happy to arrange a replacement smart hub for you. Post back and let me know if you would like to try that.
Cheers
John
Tompage51
Message 3 of 13
Hi John, thanks for the reply. It was over 6 months since the smart hub failed and I don't think it's here anymore. I believe I am still in contract and if you are able to send one out I would gladly try it to see if it helps.
Kind Regards
Tom
DanielS
Moderator
Moderator
Message 4 of 13
Hi @Tompage51,
That's great. We should be able to get it sent out for you then Smiley Happy
I've sent you a private message with some more info.
DanielS
Tompage51
Message 5 of 13
Hi Daniel / John
private message repiled to.
Kind Regards
Tom
Tags (1)
DanielS
Moderator
Moderator
Message 6 of 13
Thanks @Tompage51,
I can see your message in our queue. One of the team will be in touch with you over the next couple of working days Smiley Happy
DanielS
NeilO
Moderator
Moderator
Message 7 of 13
Hi @Tompage51 I gave you a call there but missed you, I wanted to follow up with you to check if the new Hub has resolved the IPC6023 error you were getting?
Tompage51
Message 8 of 13
Hi @NeilO  sorry I missed your call, the router arrived yesterday and I have plugged it in and the ipc6023 error has now fixed itself.
I can only assume there is something that has changed in the 3rd party setup that I cannot see. I'll leave the bt hub in from now on as it's working straight out of the box.
Many thanks for all your help 👍
Kind regards
Tom
NeilO
Moderator
Moderator
Message 9 of 13
Hi @Tompage51 Thanks for getting back to me, brilliant I'm glad that's sorted it for you 😀
Tompage51
Message 10 of 13
Hi @NeilO
Just a quick question, the Netgear has great parental controls that the smart hub does not have. Is there any way the Netgear router can be used with the hub 6 so I can keep some of the functions?
Kind regards
Tom
