dalespitfire
Message 91 of 137
Re: IPC6023
Something is happening as Broadband has dropped twice in the last 15 mins or so.
UHD is the best its been since the ussue started but I'm still having issues on all channels
Hopefully this is going to be fixed soon!
Essemess
Message 92 of 137
Re: IPC6023
Our broadband dipped just before I nipped out. Mrs Essemess & Mini Essemess tell me that it's OK now.
Can't check other telly channels 'cus "Eastenders is on". 😞 Will post up with results in a bit.
Many thanks to Steve_M and all involved in working on this....and a pox on the house of the call centre!
Kind regards,
Essemess
laurastandrin
Message 93 of 137
Re: IPC6023
@Steve_M I will hold you to that! Just make sure you have £200+ in ur hand lol! My friend who lives 6 houses away has lost her Internet now! God help them if kine goes ! There will be hell to pay!
laurastandrin
Message 94 of 137
Re: IPC6023
#mine
Essemess
Message 95 of 137
Re: IPC6023
BT Sport 1 HD now.....Grrrrrrr.
dalespitfire
Message 96 of 137
Re: IPC6023
Broadband is settled again now but whatever has been done has still not made a difference to the internet channels. Not restarted yet as Corrie was on but doubt it will make a difference.
dalespitfire
Message 97 of 137
Re: IPC6023
I feel your pain Essemess!
Essemess
Message 98 of 137
Re: IPC6023
@dalespitfireNot used my Kindle as much in ages. The telly trouble is probably doing wonders for my IQ!
BT TV Expert
BT TV Expert
Message 99 of 137
Re: IPC6023
Thanks, I've fed that back to the incident bridge. On a plus note I ended up getting pizza 😛
When it starts working you won't have to restart either the homehub or TV STB, the picture will just start flowing again. Your checks are very useful feedback though so thankyou
dalespitfire
Message 100 of 137
Re: IPC6023
Ooooooh. What flavour?!
I'm having to endure Selfridge cos the snooker isn't watchable. Lol.
