Showing results forΒ
Search instead forΒ
Did you mean:Β
BT TV Expert
BT TV Expert
Message 101 of 137
Re: IPC6023
Half chicken and bacon, half meateor πŸ˜„
dalespitfire
Message 102 of 137
Re: IPC6023
Good choice. Lol
laurastandrin
Message 103 of 137
Re: IPC6023
Morning guys any news on your front? Mine is still the same 😞 @Steve_M your offer looks really good at the minute lol! Feel free to buy me out of my contract at anytime πŸ˜† lol
Essemess
Message 104 of 137
Re: IPC6023
It's better, but still some minor corruption on SD and worse on HD.
It's not as bad but I imagine that there is a lot less traffic on the network this time on a Saturday morning.
dalespitfire
Message 105 of 137
Re: IPC6023
Yeah. Same. No UHD at all. HD not watchable.
BT TV Expert
BT TV Expert
Message 106 of 137
Re: IPC6023
Oh no, sorry guys, there has been a constant stream of work overnight but as you say, does not seemed to have completely resolved the issue. I will try and get a better update for you.
Essemess
Message 107 of 137
Re: IPC6023
BT Sport Europe HD ( SD Channels are the same at the moment, too )-
laurastandrin
Message 108 of 137
Re: IPC6023
Thanks @Steve_M your a diamond! More sense out of you than anyone else iv spoken to! Cheers hun.
Essemess
Message 109 of 137
Re: IPC6023
Just performed a speed check in case. Stable 16d/3u. A little lower than usual, but should be OK for the telly. IPC6023 on all interwebz cahnnels Cat Frustrated
dalespitfire
Message 110 of 137
Re: IPC6023
I'm getting 25mbps over wifi, 65 Ethernet and still staring at a green screen.
Guess thats another match I won't be watching.
Pub it is then!
