jparnell82
Message 1 of 19
ISP configuration 220
Just manually updated my G4 and ended up with ISP configuration 220 from 90 which is been on for ages. Anything significant? I seem to still have all my IP channels.
18 REPLIES 18
scointer
Recognised Expert
Message 2 of 19
Re: ISP configuration 220
Same here
SiCo
Message 3 of 19
are you on copper or fibre?
Think the ISP config for copper multicast is supposed to be 220
scointer
Recognised Expert
Message 4 of 19
Hope not as I am on infinity 2
jparnell82
Message 5 of 19
eeek.. im on infinity as well. Seems to be working OK though!
barnpiece
Expert
Message 6 of 19
On Infinity 2 here too and just got 220.
Only difference I notice is that the background to screen coming out of standby is now blue.
Richard
scointer
Recognised Expert
Message 7 of 19
Any BTTV experts 😉 around to just clarify that the 220 ISP is actually now correct for Fibre customers also please...
speedtrip
Expert
Message 8 of 19
Mine came out of s/by at circa 18.15  .... about 18.30 I tried my daily manual update, and lo & behold it restarted ...... still dont understand why it doesnt check for updates initially, and has to be 'forced'
Be interesteed to know what this 220 is for - helpful as ever that we are advised its happening ... Smiley Frustrated
jparnell82
Message 9 of 19
Its good to hear i'm not the only one doing daily manual updates!
xninian
Message 10 of 19
Hope I'm in the right place.  Have lost the internet channels and no luck with resetting, checking updates etc.
I have a g4 box and Infinity 2.   BT Sports was OK a week ago.  My g4 details are:
Manufacturer's software 17.3
Component software 2.4.0
Platform config 910
ISP 222
Others in this thread have ISP 220
Anyone any ideas?
