Distinguished Guru
Distinguished Guru
Message 11 of 15
Re: ITV Hub +
Hi @daddyneenor
there is within the itv hub player if you select Settings on the top row then from  a second row that appears About there is a option to Reset  your ITV Hub Settings  and that will require you to sign into your ITV account again
not sure if that will resolve  your issue but could be worth trying
daddyneenor
Message 12 of 15
Re: ITV Hub +
Yeah did this 3 times and it doesn't ask me to login just rest cookies
david1982
Message 13 of 15
Re: ITV Hub +
Looks like it's on Amazon prime on HD and for same price
daddyneenor
Message 14 of 15
Re: ITV Hub +
Yeah I just had notification this morning so I've signed up that way and it works. Plus point too going through amazon is its in HD whereas ITV hub app is only sd
robotman1
Message 15 of 15
Re: ITV Hub +
The only problem with Hub+ via Amazon is their inability to keep it updated. You'll find some shows only have one or two episodes uploaded and the rest of the series is missing, or some programmes never get uploaded at all. I ditched it for that reason.
