Message 1 of 8
Interference on BT TV
Hi; I am getting interference through my YouView+ BT TV box.
TV is fine, and the BT TV box shows 100% for both signal strength and quality.
I have unplugged / restarted and retuned all channels. Still the same.
Any other ideas please?
Bob
7 REPLIES 7
Recognised Expert
Message 2 of 8
Re: Interference on BT TV
How is the aerial feed split to go to both Youview box and theTV? Have a look a the cable leads. Having a long run of power lead parallel to and next to the aerial lead or HDMI lead can cause interference.  Try moving them away and at an angle.
Message 3 of 8
Message 4 of 8
Thanks, Keith;
I got a variable attenuator, which on one evening's trial would seem to be good.
Message 5 of 8
Thanks, Gomezz;
I tried that - the aerial wire was going through a piece of trunking  woth power cables. Now isolated, but in the end it seemed to be an over-powerful amplified signal in this case 🙂
Bob
Message 6 of 8
@hallsworthb wrote:
Thanks, Keith;
I thought it might help Smiley Happy
Message 7 of 8
Just to confirm, Keith, having had it on for a few weeks now, that your solution did the trick.
Regards
Bob
Message 8 of 8
Regards
Bob
Excellent Smiley Happy
