Message 1 of 14
Intermittent sound
Hi I have seen a number of people post with same issue. The sounds seems to cut out for a few seconds then comes back on it happens all the time and it's really irritating. We have only just subscribed to BT in july and are so far disappointed with it. I have tried to reset my box checked all the cables etc and the problem still exists. Any solutions would be appreciated. Thanks
13 REPLIES 13
Moderator
Moderator
Message 2 of 14
Re: Intermittent sound
Hi @Stacyshays Sorry you are experiencing sound loss on your BTTV service.
Does this only occur on Freeview channels or subscription channels or both?
Are you using a BT Hub?
Is your hub connected to the Youview box via ethernet cables or powerline adapters?
John
Message 3 of 14
Hi John it's happens on all channels. Yes we have BT hub and not it connected with Wirelss adapters. Thanks
Moderator
Moderator
Message 4 of 14
Hi @Stacyshays Just to clarify are you using wireless adapters to connect the BTTV box to the Hub?
If so please can you try and connect using an ethernet cable just to test if the fault is still happening as the adapters could be the cause.
John
Message 5 of 14
It's a fault with the YouView box, ask for a completely new one.
Message 6 of 14
Do u just call BT and request a new one? Thanks
Message 7 of 14
Yes, important to ask for an uptodate serial number, not one of the early ones that start with 14.
Message 8 of 14
Perfect thanks ill give that a go
Message 9 of 14
Good luck.
Message 10 of 14
i have tried cable still the same issue and the fibre box is in a different room from tv box.
