Message 1 of 3
Internet channels not recording when Youview box in standby?
Hi everyrone,
I've only had a Youview box since last weekend so I'm new to BT TV.
So far everything seems ok except that every programme I have set to record overnight while the box is in standby mode has failed to record if it is on an internet channel such as ESPN or Syfy.
Does anyone know why this might be happening? Recording on ordinary channels is working ok.
Thanks!
2 REPLIES 2
MartinSW
Message 2 of 3
Re: Internet channels not recording when Youview box in standby?
they should work - how have you connected the box to the home hub? Also, whch eco mode do you have the box in?
SergejsKravcenko
Message 3 of 3
Try recording not in standby mode, if you'll receive an error of poor signal - means problems with your tv aerial cable.
