andy9lawson
Newbie
Message 1 of 3
Internet connection dropped
I have 2 blue lights on my box & in settings it says I’m connected but when I go on apps it says no internet. All other devices are working
2 REPLIES 2
TimCurtis
Recognised Expert
Message 2 of 3
Re: Internet connection dropped
Maybe try a Maintenance Mode reset , look here for guidance. Try option 2 first & then option 4 if that doesn't work.
BT TV Expert
BT TV Expert
Message 3 of 3
Hi @andy9lawson - are you still experiencing this issue? If you are, I would like to set up a time with you to capture some diagnostics. Please let me know.
Gavin
BT TV expertGavinL
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on TV queries. I am here volunteering my own time to give advice, and help where I can with BTTV queries. Go here for more info.
