seasend25
Message 1 of 6
Ipc6023
Hi, i have lost my subscription channels, with ipc6023 error message and blank screen. Bt player and catchup are working, broadband speed is around 70mbps.
2 calls to bt and still no resolution. Can anybody help please?
Regards
Paul
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Ipc6023
Hi @seasend25  Welcome back to the forum and sorry you are having a fault with your BTTV service.
Did you get this resolved? If not check out the error code on What do the BT TV error codes mean? for help with this error.
Are you connected from the hub to the BTTV box via Ethernet or powerline adapters?
Did the service work ok before and this has just started to happen?
Post back and let me know and I'l be happy to help.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
seasend25
Message 3 of 6
Re: Ipc6023
Thanks john, i am connected via ethernet to router. Broadband speed is good. I am told unofficially that the problem is something to do with multicast from the exchange, but the bt call centre don't seem to know what I'm talking about. I have been without subscription channels for a week now, everything had been fine for the previous 12 months. I appreciate any assistance you are able to offer.
Regards
Paul
Moderator
Moderator
Message 4 of 6
Re: Ipc6023
Hi @seasend25  Thanks for the update and we will be happy to help you get this fixed. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Kudos”Kudos”
Community Manager
Community Manager
Message 5 of 6
Re: Ipc6023
Hi @seasend25 thanks for sending in your details. I'm really sorry for the length of time it's taking to get this fixed.
I have contacted a specialist team to get this sorted for you as quickly as possible. They may contact you directly, however I will get back in touch as soon as I have an update as well.
Community ModeratorStephanie
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Community Manager
Community Manager
Message 6 of 6
Re: Ipc6023
Hi @seasend25 I believe this issue has been fixed, could you let me know if you're still getting that error message?
Kudos”
