Message 11 of 12
Re: Issues connecting you view box to the internet
I can`t think of anything else to try, if the YouView system menu shows loss of Internet connection. Most likely a faulty box, so you are ging to need a visit.
Distinguished Guru
Distinguished Guru
Message 12 of 12
When you first switch on the Youview box if you look at
Youview>Settings >Network & Internet>Network Connection Status
Does the Connection Status say Connected  or Disconnected ?
