Newbie
Message 1 of 6
JVC LT-39C460 YouView Remote Sync
Hello,
Cant get my new TV (JVC LT-39C460) to sync with the YouView remote using the JVC code 2788.  Anyone any ideas?
Cheers.
5 REPLIES 5
BT TV Expert
BT TV Expert
Message 2 of 6
Re: JVC LT-39C460 YouView Remote Sync
Hi @Stereogwai
I work for BT and would be happy to assist with your issue. Are you able to send me your telephone number so I can investigate the issue for you? Thank you.
Newbie
Message 3 of 6
Thanks, you can phone on ****EDITED****.
Marc.
Moderator
Moderator
Message 4 of 6
Hi @Stereogwai,
Please don't post your information over the Forums. To reach @Gemma_P please go to her profile and send her a private message.
I've removed the number from your post for you Smiley Happy
DanielS
Message 5 of 6
Is there a solution please? I am having same problem with remote synch codes with my new JVC TV set.
Message 6 of 6
Used 027 successfully on DTRT1000 Youview box.
