magpie03
Expert
Message 1 of 3
Judder Channels
This happened after the latest update, then it was fixed now it's happening again!
On some channels the picture is juddering, like 4 music and Disney Junior the logo and top and bottom of screen is flickering.
Anyone else have similar issues or is it just mine?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Judder Channels
Hi magpie03,
Thanks for posting. Are you still having the problem? Are you getting any on screen error messages? Have you tried rescanning? Give us as much detail as possible and we'll try to help.
Cheers
David
magpie03
Expert
Message 3 of 3
Re: Judder Channels
Hi David thanks for reply. I managed to fix it by doing a reset. Picture is fine now!
Cheers
