ClairL
Message 1 of 23
Jumping/interference with youview
Our youview box has constant interference/jumping with recordings & when just watching channels. Our internet channels are fine. We have checked software (which is up to date) we have done factory resets and nothing helps. Has anyone else had this?
22 REPLIES 22
Moderator
Moderator
Message 2 of 23
Re: Jumping/interference with youview
Hi @ClairL
Welcome to the community forum and thanks for your post!
I'm sorry that you're having problems with your BT TV service.  Have a look at this link on our help pages: Channel problems on BT TV
Others should be along to offer further advice shortly.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Thomorob
Message 3 of 23
I can't see anything at that link that refers to this problem. I am having the same issue. Any further advice would be appreciated.
Thomorob
Message 4 of 23
Sorry but can't see anything at the link that addresses this. I am having the same issue. Any help would be appreciated. I have a Humax 2100
Moderator
Moderator
Message 5 of 23
@Thomorob Sorry about that, is it the freeview or internet channels you're having problems with?
Community ModeratorNeilO
Kudos”
Thomorob
Message 6 of 23
It is CBS action and Yesterday channels I have noticed it on when recording (not sure if they are Internet or freeview but bot are between channels 1 a and 100). The parts that jump aren't missing as if I rewind, the 'jumped' part then plays.
Moderator
Moderator
Message 7 of 23
@Thomorob Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll get our TV experts to take a look at this. You can find the link by clicking on my username.
Neil
Kudos”
Thomorob
Message 8 of 23
Hi Neil, Thank you for responding. I went onto your profile, however couldn't see the Contact the Mods link in any menu. Could you advise exactly where it is located please.
Moderator
Moderator
Message 9 of 23
Hi @Thomorob,
I've made the link available to you under my profile. Go to my profile and you'll see it under "Click here to contact the mods" Smiley Happy
DanielS
Community ModeratorDannyS
Kudos”
Thomorob
Message 10 of 23
Thanks Daniel. I found the link under Neils and have submitted my issue. Thank you both for ongoing support.
