BIOMAN1
Message 1 of 5
Just upgraded from Samsung S7 to S8 but youview app no longer working.
Just upgraded from Samsung S7 to S8 and youview app will no longer find BT Humax H3 box when try and set up app for new phone.  App just says searching.  Have tried setting Humax box again with S7 and connects up no trouble. Looking at recent Google Play reviews this is a known problem. Is there a solution that anyone is aware of as no longer able to remotely set up recordings which is very frustrating.
4 REPLIES 4
StewM
Distinguished Guru
Message 2 of 5
Re: Just upgraded from Samsung S7 to S8 but youview app no longer working.
Hi, does the BT TV app work?
Stew
BIOMAN1
Message 3 of 5
Yes. Not paired up with box by looks of it yet so will try when get home and see if that works as an alternative
BIOMAN1
Message 4 of 5
Tried using BT TV app but no different and yet works fine and records when use S7 BT app
BIOMAN1
Message 5 of 5
Any ideas as to a possible solution?
