walkerx
Recognised Expert
Message 1 of 87
Known Routers to Work with Multicast/IGMP
We have previously had a thread which listed some routers that would not work with multicast/igmp on BT Infinity, so have decided to create a thread of devices we now know work with the service.
  • BT HomeHub 3 and 4 - Automatically enabled (no option to enable/disable feature)
  • Asus RT-N66U - You must configure 'Enable VPN + DHCP Connection' to 'No' under the WAN option.
  • TP-Link TL-WR1043ND - Automatically enabled (no option to enable/disable feature)
  • TP-Link Archer C7 - Automatically enabled (can enable/disable feature)
  • Billion 7800N - Requires profile (Pure Bridge) to the EWAN port along with the PPPoE profile. Also enable IGMP Proxy/Snooping
  • Billion 7800DXL - Probably requires profile configuring similar to the Billion 7800N
  • TP-Link TL-WDR4900 N900 - Automatically enabled
  • TP-Link WDR4300 N750 - Automatically enabled
thanks go to the following members who have helped in testing their equipment to see if it works
TimCurtis, zarf2007aseymourcactusbobRed_Snowsepph
If we find which other routers work, lets add them to this thread
regards
Walkerx
86 REPLIES 86
Red_Snow
Message 2 of 87
Re: Known Routers to Work with Multicast/IGMP
Great thread and good information to consolidate. Perhaps the mods should "sticky" this one.
Cheers, Mark
Distinguished Guru
Message 3 of 87
Most helpful. This would Mae a good sticky thread!
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
walkerx
Recognised Expert
Message 4 of 87
Can a mod please make this a sticky. Can the first post also be made editable when we want to add more working devices
Message 5 of 87
Walkerx,
Would it help if I added it to my website, as I can easily add more if someone updates me?
I have done this before, for the home hub 3.
As its unsupported by BT, the mods would not be able to add it as a sticky.
walkerx
Recognised Expert
Message 6 of 87
Yeah, good idea
Message 7 of 87
@walkerx wrote:
Yeah, good idea
I will copy the info you have provided, including the acknowledgements, and post the link on this thread later.
Message 8 of 87
How about this link, is that what you would like to see?
If you want more added, then please ask.
walkerx
Recognised Expert
Message 9 of 87
Thanks Keith, that should do nicely
Message 10 of 87
Just refer people to the link, if it helps. Please let me know of any updates. You can use the PM facility if you wish, and I will update the page when I get a moment.
Its hosted locally, so its easy to edit.
